TwinTurbo.NET: Nissan 300ZX forum - Is mil on ck codes tps iac timing vacuum leaks fpr. Get help (n/m)
craigz96tt
on August 11, 2012 at 1:30 PM
running wrong
posted by 300zxswap
on August 11, 2012 at 01:26 PM
running wrong
300zxswap
13:26:30 08/11/12
Is mil on ck codes tps iac timing vacuum leaks fpr. Get help (n/m) -
craigz96tt
13:30:44 08/11/12
Re: Is mil on ck codes tps iac timing vacuum leaks fpr. Get help
300zxswap
13:33:47 08/11/12
Krazyd27(Houston)
14:19:01 08/11/12
Re: Re: Is mil on ck codes tps iac timing vacuum leaks fpr. Get help
300zxswap
14:49:19 08/11/12
Perform a power balance test. This should give you a
white22sky
14:37:44 08/11/12
Re: Perform a power balance test. This should give you a
300zxswap
14:48:43 08/11/12
